Low power and running rough
2000 NISSAN FRONTIER
186,000 MILES
DAVID GOOTEE
  • 8 POSTS
Truck starts and idles okay, I can drive a short distance and loses power. Replaced knock sensor, replaced throttle positioning sensor, It does take off slowly then picks up like i said; then can drive for a short distance and starts running rough.
Feb 23, 2020 at 6:08 AM
Good morning,
This could be from low fuel pressure. I would check the actual pressure.
It could also be a clogged catalytic converter. If it is blocked, the engine cannot breathe and will result in low power.
https://www.2carpros.com/articles/engine-has-low-power-output
Feb 23, 2020 at 9:37 AM
DAVID GOOTEE
  • 8 POSTS
Sorry i forgot to mention the catalytic converter was removed by previous owner.
Feb 23, 2020 at 10:55 AM
Okay, back to fuel pressure.
Feb 23, 2020 at 11:00 AM
DAVID GOOTEE
  • 8 POSTS
Thank you. i will check fuel pressure.
Feb 23, 2020 at 12:18 PM
You are welcome.
Keep us updated.
Feb 23, 2020 at 12:20 PM
DAVID GOOTEE
  • 8 POSTS
Will do.
Feb 23, 2020 at 4:17 PM
DAVID GOOTEE
  • 8 POSTS
Before i replace fuel pump, I noticed i could hear fuel pump come on. does that mean fuel pump is okay?
Feb 26, 2020 at 7:39 AM
No, it does not. You can have the pump working but if the pressure is too low, it will cause your issue.
Feb 26, 2020 at 9:11 AM
DAVID GOOTEE
  • 8 POSTS
Thanks again.
Feb 26, 2020 at 10:02 AM
You are welcome.
Always glad to help.
Feb 26, 2020 at 11:12 AM
