Low Oil Pressure Warning Light Does Not Light
1989 TOYOTA TERCEL
224,000 MILES • 1.5L • 4 CYL • FWD • MANUAL
ZAKTERCEL
  • 9 POSTS
Just noticed recently that this warning light isn't coming on. Service manual says to check 4 things: 1) Gauge fuse is blown, 2) bulb is burned out, 3)Low oil pressure warning switch is faulty, 4) wiring or ground faulty.
I want to check-out my thinking around these 4 things. First, if the gauge fuse is blown, wouldn't other things (like the brake warning light) also not work? Second, if a bulb is burned out, does each warning light have it's own bulb? Is accessing that something that should only be done by a very experienced person? Third, for the low oil pressure warning switch, it says to Disconnect the connector from the pressure switch and ground the connector on the wire harness side. I am imagining that means to take the wire off the switch and then connect it to a metal part of the chassis. Is that correct?
Any other thoughts or suggestions on problem-solving this?
Thanks!
Zak
Nov 22, 2015 at 10:10 PM
HMAC300
  • 48,601 POSTS
ground out the wire on oil pressure switch with key on if light comes on it may be a bad switch. if not then check for a burnt out bulb
Nov 23, 2015 at 8:06 AM
ZAKTERCEL
  • 9 POSTS
Hi HMAC -
I am feeling like an idiot on this. I can't figure out how to ground out the wire. Any suggestions?
Dec 31, 2015 at 8:00 PM
HMAC300
  • 48,601 POSTS
take the wire off the switch and touch to engine see if light goes on.... have an assistant look for it.
Jan 1, 2016 at 6:46 AM
ZAKTERCEL
  • 9 POSTS
Hi HMAC - I tried this again on Saturday. Took the connector off the switch. The metal part of the connector is recessed in plastic. I was concerned about pulling the wire off the connector, so I took a wire with stripped ends and touched it to the metal part and the engine. No light. Does that sound like an acceptable way of testing, or am I missing something?
I am thinking I need to move onto the light bulb now, but I can't find any instructions in the Toyota Service Manual, Haynes, or Chilton on how to access the light bulb in the dashboard. Any suggestions?
Jan 11, 2016 at 9:58 PM
HMAC300
  • 48,601 POSTS
ya that was okto do. hope your key was on whe n you did it. you'll have to pull cluster out to change bulb
Jan 12, 2016 at 6:10 AM
