I recently got an oil change done at Valvoline. Before going the car was running perfectly fine and was at 15,000 miles since the last oil change. The day after the oil change I was driving up through a mountain pass, as I neared they top the low oil pressure warning can on and I was lucky enough to be able to turn off the highway right away and shut the car off. The vehicle was towed back to my place. Thinking Valvoline did not add enough oil my father in law decided to drain the oil and do another oil change. Upon draining the oil he discovered that there was nearly 7 quarts of oil.
After completing the oil change and resetting the check engine lights we decided to test the car. After about 200 feet the light turned back on.
The car runs on 0w-16 full synthetic oil. So all oil changes were done around 10,000 to 15,000 miles.
Any advice or feedback will be greatly appreciated. Thank you in advance.
Jul 9, 2020 at 10:59 AM
