My truck has low oil pressure and the mechanic shop (they're reliable) said it's the oil pump. I am doing the work myself and have the know how, but what else should I replace while I'm at it. I bought a high volume oil pump so the engine can get more oil faster, oil pump gasket, the pickup tube and screen, a rubber one piece oil pan gasket, WIX oil filter, and Lucas high mileage oil stabilizer. Should I run thicker oil and if so, what weight? What sensors and what not should I replace like an oil pressure sending unit or relief valve of some type? Should I also replace the main bearings with the engine still in and check the crankshaft for gauges while I have the oil pan off? Thanks for any help!
Nov 19, 2020 at 7:40 AM
