Hi, I need someone to help me out real bad as this year my car has been in the workshop more than on the road .
My car has been having radiator problem from beginning of 2019 hence I changed all the radiator parts on my car to find out it was a blown head gasket .
I had changed one of the short runner valves as well the knock sensors because of the radiator problem.
After I got my car it was fine for a couple of weeks but later I had given it a sudden rev and stopped and the rpm was below idle (750) . It would stay on idle when I would go at 80 km/hr and stop . it would stay for a while but would drop later . No check engine light as well . I changed the air filter but no change in the idle . Currently even after I start my car it goes straight to low idle and stays there between 750 and 500. If I brake too hard it may touch 500 . So when i am at traffic light i put the gear neutral and it would be fine
I had checked for codes I found a code for 1004 but it wasn't written P1004.
Nov 25, 2019 at 1:20 AM
