low idle
2004 FORD FREESTAR
175,000 MILES • 4.2L • V6 • FWD • AUTOMATIC
STEVE MURRAY
  • 6 POSTS
van runs rough until 2000 rpm idle drops the warmer van gets.
May 31, 2017 at 1:17 PM
STEVE W.
  • 15,113 POSTS
Classic symptoms of a vacuum leak. Probably needs intake manifold gaskets. The manifold cools down overnight and pulls away slightly, You start the engine and it draws in excess air giving you a high idle and rough. As it warms up the parts expand and start to seal back up and the engine runs better because it is now under computer control. These are common for leaks between the upper and lower intake manifold sections. The pictures show the o-rings and lower gaskets that fail. Normally I test both the upper and lower gaskets, It is not that much more work to do the lowers as you have the engine apart anyway,
May 31, 2017 at 3:35 PM
STEVE MURRAY
  • 6 POSTS
I have change them and the revs get worst when it warms up
Jun 6, 2017 at 5:39 AM
STEVE W.
  • 15,113 POSTS
What are they when you start it vs once it warms up? Do you have access to a scan tool? I'm wondering if the ECT sensor is acting up as well. Does it start hard as well as idle wrong?
Jun 7, 2017 at 1:54 AM
STEVE MURRAY
  • 6 POSTS
it starts first try the revs are 1100 and when it warms up the go between 800 to 500 rpm I don't have access to a scan tool
Jun 10, 2017 at 3:53 PM
STEVE W.
  • 15,113 POSTS
OK so on cold start it revs to 1K, that's common as the engine tries to warm up quick. Then it should drop back to around 650 or so and stay there. Try cleaning the throttle body and the idle air control ports, Then test the IAC for operation. Normally they fail and stick in one spot but it's possible it's sending bad data.
Jun 12, 2017 at 6:29 PM
STEVE MURRAY
  • 6 POSTS
the throttle body has bin cleaned and the iac has bin changed
Jun 17, 2017 at 1:23 PM
STEVE W.
  • 15,113 POSTS
OK so you cleaned the TB, IAC is good and no vacuum leaks. But it still acts up.
At this point you really need a scan tool with live data to see what the timing and fuel trims are doing. The engine coolant temperature sender on these likes to cause problems but without a scan tool you can't see if it is the problem.
Jun 18, 2017 at 4:31 AM
STEVE MURRAY
  • 6 POSTS
ok got a scan tool and when you rev it quick to 2000 rpm the vacuum goes from 18 down to 2 than up to 20
Jun 24, 2017 at 5:39 PM
STEVE W.
  • 15,113 POSTS
What does the coolant temperature sender show on a cold engine and once it warms up?
Jun 25, 2017 at 5:41 AM
STEVE MURRAY
  • 6 POSTS
Ill find out tomorrow and let you know
Jun 25, 2017 at 8:35 PM
Jun 28, 2017 at 5:05 PM
