Came from work parked car next day went to start engine just swings. Removed battery terminal rest computer box started one shot switch off do not start. Drove the car to mechanic at his place switch off an now it just swings. Checked spark, fuel pressure, changed all sensors ,checked compression all five cylinders. It has low compression 90 psi on all cylinders. Checked timing, checked belt, checked cams. Took out plugs put in some oil, put plugs back in to built compression engine just swings. Does not start please I can really do wit lots off help. Will 90psi not start the car?
Oct 26, 2018 at 9:58 PM
