Low Charge?
2006 NISSAN MURANO
140,112 MILES • 3.5L • 4 CYL • 2WD • AUTOMATIC
MOO2CAR
  • 59 POSTS
I measured the pressure on the low- and high-pressure side of the car today, Results as follows:
Outside temperature - 86F
Pressure low side - 26 psig
Pressure high side - 180 psig
Temp out of vent 62F
From these results, it looks like low charge. Should I recharge after having the refrigerant evacuated at a shop?
I enclose a video of the engine and A/C running during the measurement. There is a click-click sound that can be heard in the background. Can you tell me what this sound denotes? Hope it doesn't have to do with the compressor.
May 28, 2024 at 10:14 PM
If you turn the A/C system off the noise should go away if it is compressor related, to me it sounds like a loose spark plug or an ignition system leak. See if you can get a better idea of where the noise is coming from and go from there, you can start a new thread for the noise and upload a video closer to the noise to help us see what's going on, as afar as the A/C system, yes I would do a vacuum down and recharge.
This video should help:
https://youtu.be/4EqdrBVb0sY?si=IVDFgZD-CLiwd03V
This guide can help as well:
Please go over these guides and get back to us.
May 29, 2024 at 9:25 AM
MOO2CAR
  • 59 POSTS
I evacuated it but could not get it to hold vacuum. So I took it to a shop. They evacuated it and refilled it with a dye and told me to bring it back if it loses refrigerant, so they can detect where it has been leaking.
Jun 15, 2024 at 7:13 PM
Nice work, also the dye will be tough to see if the front seal of the compressor is leaking.
here is a guide that works well if you park the car out of the wind like inside a garage:
https://www.2carpros.com/articles/air-conditioner-leak-detection
Jun 16, 2024 at 12:22 PM
