Low beams not working
2012 VOLKSWAGEN JETTA
90,000 MILES
DARREN T DUNCAN
Changed bulbs still not working. Can't find fuse box diagram to check the fuse or relays.
Jan 28, 2021 at 2:57 PM
There are two fuses for the low beam, one for each side.
If you look at pic 1, I highlighted the two fuses related to the low beam. The fuse box for these is fuse box C (left side under the dash). I attached a pic of the box and the relevant fuses to check.
Let me know if this is what you needed or if you have other questions.
Jan 28, 2021 at 4:55 PM
