The low beams cut out intermittently. I tried a new #46 relay and it still is doing the same thing. On and off with no rhyme or reason. Also, this vehicle also has a battery drain problem. The battery was draining overnight. I used a meter to determine that a draw was coming from the radio. I pulled that fuse and the battery no longer drains. Could there be any relation? First priority is the lights.
Jan 23, 2021 at 4:59 PM
