Low beam headlights went out completely. High beams work fine. Where is the headlight relay located? My Haynes book shows 3 fuses around the relay, but there are only 2 in the fuse box. Is the other one a fusible link?
I took the steering column covers off to try & ohm out the combination switch, but the connector is different than those described in the book. It's a 16 pin connector that only uses 11 pins. The ones they talk about in the book are a 10 pin connector and a seven pin & 4 pin.connectors option.
Any help on this problem will be greatly appreciated.
Thanks,
JC Heinen
Thanks,
JC Heinen
Sep 27, 2013 at 7:42 PM
