Right side low beam headlight will not work. I tried replacing bulb, then verified fuses, then swapped bulbs left to right which verified bulbs are okay, but problem on right side. Rechecked fuses with multi-meter and these are good.
This appears to be a common problem based on the internet complaints but i have not found a common remedy.
Any thoughts or suggestions would be appreciated.
Where is the ground located, to check it? Is there a relay that can be checked easily?
Apr 11, 2017 at 8:55 PM
