Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Honda
CRV
Suspension
Symptoms
Loud
After replacing the suspension there is a loud howling noise?
2001 HONDA CRV
200,000 MILES • 4 CYL • 4WD • AUTOMATIC
CYNTHIA WALKER
MEMBER
1 POST
FOLLOW
just replaced complete all-around suspension. took a test drive and 35 MPH a loud howling noise starts.
Apr 8, 2024 at 7:32 PM
CERTIFIED EXPERT
Have you checked to make sure nothing is rubbing? Is the sound loud enough to record and upload for me to hear?
Also, when you replaced them, did you replace the entire strut assembly or only the shock portion?
joe
A howling sound is usually the result of a failed bearing (wheel/hub). Does the sound change pitch when making turns?
joe
Apr 8, 2024 at 7:46 PM
CERTIFIED EXPERT
This is common when the bearing hub goes out, depending on which side you hear the noise on, here is how to change the hub out.
Here is a video to show how to press out the axle bearing with instructions below for your car:
https://youtu.be/_FzmmBoa4Tg?si=Y7DM7_yCRMz53x-d
Check out the images (below). Please upload pictures or videos in your response to the problem so we can see what's going on.
Apr 9, 2024 at 6:45 PM
