Van listed above is a CE model.
Car won’t move when switching gear (gear switch without any issues). Whenever I switch from any gear to “park” I hear a loud buzz coming out from the transmission around the linkage area. No signs of broken shift linkage anywhere.
Checked driver axle shaft and it looked fine. I also took down the transmission pan and changed the filter and gasket.
Fluid is to the right level as far as I can tell. Please help, Thank you!
Oct 13, 2019 at 10:02 AM
