Power seems okay blue smoke (always) cold, hot idle,and run down the street (lots off almost like a sea foam treatment) . Spark plugs has carbon cylinder 4 spark plug pretty dirty (black)
compression good psi: cyl 1=210 ,cyl 2=205,cyl 3=185 after adding oil to spark plug hole =205 psi, cylinder 4 205 --(compression tester gauge might be a little off maybe to high.) new PCV valve,new ignition module.
1.Could this me a bad/plugged crankcase ventilation system,oil separator?
2. piston rings.
3. Valve seal or worn valve guides.
Help please
2. piston rings.
Help please
Oct 15, 2019 at 10:39 PM
