Lost keys
1999 FORD F-150
170,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
88CJR
I lost the original keys to the truck and at the time thought I could go to the auto parts store and get new ignition and key that didn't work. Tried changing the steering column with a new key didn't work dealership said I need a new PCM $800.00 to fix it and get programmed keys. is this my only option?
Apr 16, 2019 at 1:28 PM
SCGRANTURISMO
  • 4,897 POSTS
You can get your new keys programmed to the existing PCM at either the dealership or a locksmith. I am not sure why they told you need a new PCM, but you can get a new lock cylinder with keys and have them programmed. Call your local locksmith and inquire with him.
Thanks,
Alex
2CarPros
Apr 16, 2019 at 3:46 PM
BMDOUBLE
  • 1,139 POSTS
I don’t understand why they would try to sell you a PCM! This is a ten minute solution, clear existing key codes and program minimum two new keys, and done.
Apr 16, 2019 at 6:41 PM
