I bet I get a couple responses telling me I need to get a new truck with the miles I have but it runs good. Problem, for several years I smelled coolant when I turned on the heater, but I waited to deal with the problem until it got so bad it started fogging up the inside windshield. I had a shop replace the heater core about six months ago and everything was fine until I went on a 1,500 mile trip, then I started smelling the coolant again and the window started fogging up. I took it back to the shop that did the work and he said I lost one to one and half gallons of coolant and it must be a head gasket leak not the heater core. The truck does not over heat and runs good, no rough idling. He said compression test showed no leak down, changed oil, no milky oil. Coolant in the radiator does not show any oil in the coolant. said he did a dye test and it turned yellow and did a six point analysis and it showed 20PPM of Oxygen and 9ppm of HC in the radiator. I had a safety check done before I left on vacation and was told everything okay. So how do I lose this much coolant in five days and 1,500 miles? I think it is the heater core again and not a head gasket as the mechanic claims. He says the gasket leak caused pressure to build up and is causing the heater core to fail. Any ideas?
Charles
Charles
Mar 28, 2018 at 3:58 PM
