Air conditioner and headlights not working
2004 CHEVROLET SILVERADO
100,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
CANEMASTER56
  • 4 POSTS
Noticed air conditioning won't come on. was working great when I push the button to turn it on it flashes like 3 times and turns off. also noticed I lost running lights and when I checked my headlights lost them too. Hope it's nothing too bad. need some help please.
Aug 23, 2020 at 11:05 AM
I just went through wiring schematic for the A/C, exterior light, and headlamps. Nothing it tied together for all of them except the body control module.
Before I suggest replacing anything, check the body control module (BCM) connection for corrosion, damage, make sure it's tight.
The BCM is below the steering column. You need to remove the plastic cover under the column to get good access. See pics 1 and 2.
Now, there are a number of fuses that can cause issues, but none of them will deal with all the issues you have. Also, the lights, A/C, headlamps have different grounding locations. So, that doesn't seem like the cause. That is why I'm suspecting something has happened at the BCM.
Aug 24, 2020 at 8:17 PM
CANEMASTER56
  • 4 POSTS
I will check it out and let you know.
Aug 25, 2020 at 6:51 AM
That sounds like a plan. I look forward to hearing from you.
Aug 25, 2020 at 8:02 PM
CANEMASTER56
  • 4 POSTS
Hey Joe,
Just one more thing. air is coming on it's cold on passenger side but very hot on drivers side. just wanted to let you know. Still trying to check out DCM, but there is a hurricane going on right now in my area. so still hunkered down.
Aug 27, 2020 at 8:53 AM
Not a problem. Whenever you have a chance, let me know. I hope you are okay. I have seen damage and what has been going on. I'm up north of you guys. Stay safe!
Aug 27, 2020 at 8:20 PM
CANEMASTER56
  • 4 POSTS
Yes, checked the DCM looked okay. do you have any other options for me? my truck is hard to drive with the hot air blowing out of the drivers side even when I have the air conditioner off. hopefully it is something I can fix. thank you sir .
Aug 30, 2020 at 12:47 PM
The heat on one side and A/C on the other is usually the result of a faulty blend air door. Here is a link that explains how in general to replace one:
I attached a pic below that shows where it is located on your truck.
Let me know if that helps.
Aug 30, 2020 at 9:43 PM
