Yep, that makes perfect sense. Thanks for letting me know. I don't know if you need them, but here are the directions for replacing the chain and sprockets. The attached pics correlate with the directions. I honestly would replace the sprockets and tensioner while it's apart.
___________________________________________________
1998 Chevy Truck S10/T10 P/U 2WD L4-2.2L VIN 4
Timing Chain & Sprocket Replace
Vehicle Engine, Cooling and Exhaust Engine Camshaft, Lifters and Push Rods Camshaft Gear/Sprocket Service and Repair Removal and Replacement Timing Chain & Sprocket Replace
TIMING CHAIN & SPROCKET REPLACE
REMOVAL PROCEDURE
^ Tools Required
- J 22888 - 20 Crankshaft Gear Remover
pic 1
1. Remove the engine front cover.
NOTICE: When using the crankshaft balancer bolt to rotate the engine, install sufficient spacers on the bolt to prevent the bolt from going to far in the crankshaft and damaging the threads of the bolt.
IMPORTANT: Make sure the camshaft sprocket alignment mark, which is an 8 mm hole, and the stamped circle in the crankshaft sprocket align with tabs on the timing chain tensioner.
2. Rotate the crankshaft until the number 1 piston is at Top Dead Center (TDC) of the compression stroke.
pic 2
3. Remove the camshaft timing chain tensioner bolts.
pic 3
4. Remove the camshaft timing chain, tensioner and camshaft sprocket at the same time.
pic 4
5. Use the J 22888 - 20 in order to remove the crankshaft sprocket.
6. Remove the crankshaft sprocket key, if necessary.
INSTALLATION PROCEDURE
^ Tools Required
- J 5590 Crankshaft Gear Installer
IMPORTANT: If any of the camshaft drive components are being replaced to correct a noise condition, replace all of the components in the camshaft drive system.
pic 5
1. Install the crankshaft sprocket key, if removed.
2. Install the crankshaft sprocket with the timing mark facing away from the engine, using J 5590 and a hammer.
Make sure that the crankshaft sprocket is seated against the crankshaft.
pic 6
3. Compress the timing chain tensioner spring.
4. Insert a cotter pin or a nail into the hole in the tensioner in order to retain the timing chain tensioner shoe.
pic 7
IMPORTANT: Do not tighten the timing chain tensioner bolts.
5. Install the timing chain tensioner.
pic 8
6. Align the crankshaft sprocket timing mark, the stamped circle, with the tab on the timing chain tensioner.
7. Align the camshaft sprocket timing mark, the 8 mm hole, with the tab on the timing chain tensioner.
8. Install the camshaft sprocket and the timing chain.
NOTICE: Refer to Fastener Notice in Service Precautions.
9. Install the camshaft sprocket bolt.
9.1. Tighten the timing chain tensioner bolts to 24 Nm (17 ft. lbs.).
9.2. Tighten the camshaft sprocket bolt to 130 Nm (96 ft. lbs.).
pic 9
10. Remove the cotter pin or nail from the hole in the timing chain tensioner.
11. Install the engine front cover.
I hope this helps. Let me know how things turn out for you or if you need help.
Dec 7, 2020 at 7:06 PM
