Loss of power backfires
1999 OLDSMOBILE AURORA
200,000 MILES • 3.6L • V8 • 2WD • AUTOMATIC
DAVID GENTER
Changed plugs wires, air filter. idles rough in drive, consumes a lot of gas and loss of power.
Sep 28, 2019 at 9:03 PM
Hi David,
I attached a couple of guides that will take you through the most common causes of this type of issue. Give these a read and tell me what you think.
https://www.2carpros.com/articles/engine-backfires-while-running
https://www.2carpros.com/articles/engine-has-low-power-output
My bet is on a vacuum leak because I have seen similar issues on one of these and that was it. Also, we need to check for codes before we get to far because that will narrow this down and save a lot of time. If you can't pull codes, then most parts stores can do this for you free of charge.
Let me know and we can go from there.
Sep 29, 2019 at 3:21 PM
