My vehicle has a slight loss of power at times and if I turn the A/C off you can feel it gain power instantly, but when im stopped in gear it will idle erratically then even out. but soon as I attempt to accelerate it will almost stall, some days I get in tho and it's ready to go like it's running perfect. I have pulled the plugs they look great, I tested the coils with multimeter and all 6 are almost exact same readings. the truck was owned by a elderly couple who took care of it and all the service has been on schedule. now the stepper motor for the oil "pressure" gauge went bad so I removed the pressure sensor and bought a mechanical gauge, but when I was changing it I figured I'd pull the VT solenoid and clean it and test it. so I immediately noticed the plastic and all that is encased in the metal housing will spin freely inside the metal which I've never seen any do that the 2 on my beamer don't, so i'm suspect that its bad or going bad. however I have used a foxwell nt 510 Elite obd2 scanner and there is no pending or stored codes and no check engine light. I did plug it in last night and collected some live data i can provide you with.
Jul 20, 2021 at 11:39 AM
