Loss of power
2008 VOLVO C30
98,000 MILES • 1.6L • 2WD • MANUAL
JONNY5MCD
  • 4 POSTS
About a month ago my car lost power on the motorway from around 70 mph down to around 25 mph. i had to stop and restart again and that worked. but recently it has started happening more often. The power just drops, i put it in second gear put my foot too the floor and after about ten to fifteen seconds the power comes right back up.
Any ideas?
Thanks
Mar 5, 2019 at 1:10 AM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with your Powertrain Control Module(PCM) AKA,"computer" or your Computer Area Network (CAN) system. I have included a couple of links down below.
https://www.2carpros.com/articles/engine-has-low-power-output
https://www.2carpros.com/articles/symptoms-of-low-engine-power
Please go through these guides and get back to us with what you find out.
Thanks,
Alex
2CarPros
Mar 5, 2019 at 1:37 AM
JONNY5MCD
  • 4 POSTS
Thanks, I'll check those out.
Mar 5, 2019 at 2:26 AM
Mar 7, 2019 at 10:34 AM
JIS001
  • 3,412 POSTS
Just to add also, has the check engine light come as well? If it has can you have the codes retrieved. If you have codes indicating a behavior fault then a software update for the ECM should take care of the issue you have.
Mar 14, 2019 at 9:36 PM
JONNY5MCD
  • 4 POSTS
Hi guy's, this was the problem.
Mar 19, 2019 at 4:00 AM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Mar 19, 2019 at 10:44 AM
JONNY5MCD
  • 4 POSTS
Sure will, cheers.
Mar 19, 2019 at 10:52 AM
