First, the interesting thing about this is that every component not working has a different power supply. The chances of several fuses for different circuits to blow at the same time is really slim.
I decided to check for ground distribution to see if there was a tie in to the things you mentioned, and there is. Behind the left kick panel (where your left foot would touch when sitting in the driver's seat) there will be several white wires with a black tracer and one orange wire all going to the same ground (G200). See pic 1. I have a feeling that grounding location has failed. The only way to check is to remove the left kick panel, locate the wires and where the bolt to the body of the vehicle, and inspect them to make sure nothing has broken, corroded, or come loose.
The panel is being referred to as the cowl side trim board in pic 2. It will be behind the brake pedal.
Let me know what you find. Please keep in mind, electrical issues can be somewhat difficult to locate, so bear with me. At this point, the ground is the only thing that is making sense to me.
Take care and let me know.
Jun 28, 2020 at 8:23 PM
