Loss of power, ECM light is on
2008 CHRYSLER SEBRING
220,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
OREGGIE
Rough idle with shaky engine and rpm's at 1,500-2,000. ECM light is on. Car won’t accelerate past 20-30 mph and gets there very slowly. Engine diagnostic came back with p0456 and p0457 which shouldn’t be causing this issue. I changed the spark plugs and put gas cleaner through the tank. Pushing the accelerator to the ground does not increase rpm’s unless in park.
Jul 14, 2019 at 2:25 PM
It sounds like the throttle bore has lost correlation with the PCM due to coking which will cause the car to be in limp mode.here is a guide to help fix it:
https://www.2carpros.com/articles/reduced-power-limp-mode
Jul 15, 2019 at 5:45 PM
JUICE614
Which ECU, ECM fuses on my car listed above?
Sep 14, 2019 at 6:08 PM
Please post your new question here, you must be logged in.
Sep 16, 2019 at 10:28 AM
