I replaced, timing belt, water pump, tensioners, pulleys, intake gasket, tune up, MAP sensor, coolant temperature sensor, TP sensor, new transmission filter, and fluid, radiator, and cam position sensor. all pretty much when I got the car for my wife, and we just got the car. It just started acting like it doesn't want to accelerate when I press the gas and starts to slow down. When I let off the gas and press it again it will start speeding up. At idle it will start to run rough then act like its about to stall then catch its self. I have a bank 1 sensor 1 code, transmission pressure sensor code and I think 2 transmission gear out of sync codes I believe and a few more codes related to the transmission. I can get the actual codes if anyone needs them I'm trying to figure out if a 02 can cause this, but the o2 looks new and puts out the correct voltage. Or is the problem related to a transmission output sensor or control module? I am a mechanic and went to school to be one but to be honest I'm just starting out and still learning and my electrical diagnosing skills could use some sharpening up, it was always a hard subject for me to learn. Does anyone have any ideas or advice on were to start and how to go about diagnosing?
Feb 13, 2019 at 4:52 PM
