After filling up with gas engine was hard to start when it did ran bad then would die. Found codes referring to cam sensor problems, replaced cam sensor and code for cam sensor was gone, also replaced catalytic converter and now engine will start and run but for only about 30 seconds then fuel pressure would drop to 20 psi and engine would just about die then recover for a few seconds then fuel pressure would drop again, replaced both fuel pumps and seemed to be ok? After driving for about 100 miles the same problem has returned only now after driving for about 10 miles loss of fuel pressure occurs and then happens sooner and sooner, replaced with another fuel pump ran ok for awhile then died again. Somehow loosing fuel pressure ? I am at a loss. Any suggestions??
May 25, 2013 at 7:48 AM
