Skoda specialist work carried out.
1. Carried out coolant pressure tested with no leak found and fault in memory..
2. Checked for water in EGR cooler no fault found.
3. Check for leak in car with no fault found.
4. Test drove found that engine is creating massive pressure and blowing water pass coolant cap!
Finally mechanic suspected internal engine fault will require engine strip possible or head gasket or head damaged block or charge cooler fault?
Dec 17, 2020 at 9:14 AM
