If the check engine light is on, the first thing you need to have done is scan the computer for trouble codes. That will guide us to what is causing the problem. Many things can cause it.
First, here is a video that shows how to check for trouble codes:
https://youtu.be/YV3TRZwer8k
Sounds like it is most likely a transmission issue, does the speedometer work?
read this guide on transmission issues, it will help
https://www.2carpros.com/articles/automatic-transmission-problems
Nov 26, 2018 at 1:47 PM
