losing power
1993 HYUNDAI GETZ
540,000 MILES
SUE_MARIE
my hyundai getz loses power on a climb,even a slight slope,can only manage in 1st and 2nd gear with very high revs. ive had a full sevice,changed cat convertor,new fuel pump,i recently put in injector fluid which seemed to solve the problem for a short while and its now doing the same
May 12, 2013 at 10:30 AM
sounds like your clutch is slipping here is a video of the repair on a similar car so you can see how the job is done.
https://youtu.be/6N6b5F2ChyE
Please run down this guide and report back. Roy
May 12, 2013 at 10:39 AM
SUE_MARIE
no clutch is fine,not slipping
May 12, 2013 at 10:44 AM
JAGGERJACK06
  • 14 POSTS
well it sounds to me like there is still a problem with your fuel system. I would reccommend scanning for error codes in the engine and doing a compression test on all cylinders and a fuel pressure test & advise from there with results
May 22, 2013 at 3:42 PM
JAGGERJACK06
  • 14 POSTS
also what year model is your vehicle? there is no such thing as a 93 getz as it was first produced in 01-02
May 22, 2013 at 4:33 PM
hello guys me also i have the same problem with SUE- marie. loses power on a climb, even a slight slope
Apr 15, 2017 at 8:07 PM
I would check the engines air filter and the fuel filter, do you have a new fuel pump like the SUE_MARIE?
Here is a guide that can help you get the problem fixed as well.
https://www.2carpros.com/articles/engine-has-low-power-output
Best, Ken
Apr 18, 2017 at 11:57 AM
