keeping oil from coming out threaded hole?
2003 HONDA CIVIC
250,786 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
STOCKTON
  • 5 POSTS
There is a threaded hole right above my oil filter that goes into the engine that does not have a plug or anything keeping oil from coming out. what would that threaded hole be called?
Oct 16, 2024 at 3:53 PM
OCTANE1Z
  • 40 POSTS
That should be where an oil pressure sending unit goes into the block.
Oct 16, 2024 at 6:21 PM
I agree with OCTANE1Z, here is the oil pressure sender location to see if it matches up. Check out the images (below). Let us know if you need anything else.
Oct 16, 2024 at 7:24 PM
It sounds like you answered your own question. You are correct. That is where the oil pressure switch goes. I attached a picture below. Is that where you are referring?
See pic below.
Oct 16, 2024 at 7:27 PM
STOCKTON
  • 5 POSTS
Hello, thank y'all so much I have replaced it, and it is no longer losing oil and thank y'all.
Oct 16, 2024 at 9:31 PM
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Oct 17, 2024 at 8:46 AM
