I have a problem with engine losing oil but no leak and no smoke visible.
A couple of weeks before i changed my all engine cause i had an overheating problem and losing a lot of oil without leaking but a lot smoke and losing power.
With the new engine i can see the power difference driving in mountains with 4 people on it is everything perfect in high gears and low rpm but still the same problem with oil. I'm losing oil. Every 100km my car dashboard will get on the yellow light with oil figure and under it is written "min".
The first time using this new engine i drove for around 500km and i have lose around 200 ml oil and i noticed a lot of oil on spark plugs so i changed directly the valve cover gasket, but still the same i am losing oil but no leaking no smoke from exhaust and if my car is started and i open the oil cap is nothing to suspect no oil coming up everything work fine.
My question is, what can be the problem?
And if i use an air oil separator or oil catch can do i save oil or i will lose the same oil amount?
Thank you
My car listed above B6 with engine 2.0ALT. it doesn't have turbo or FSI is simple 2.0 with "ALT" engine code.
Sorry for my poor English.
Thank you
Jun 5, 2020 at 2:16 PM
