So am I am losing coolant, or in the case water, at an alarming rate. I took it to a mechanic and got royally taken advantage of because the issue still exists. He ran every test under the sun, pressure test, tested the radiator, he swears it is not an overheating issue, which I somewhat agree with, however, the coolant being lost is causing it to overheat. He said the head gaskets are good, no cracked block. I do not know what else there is to check here. I even bypassed the heater core, because I was getting a slight drop of fluid inside the car, so I suspected it might be the heater core, that apparently is not it either. Please help! Please let me know what other details you might need to diagnose this issue. The car ran fine and would not overheat as long as I kept fluid in it, as of right now, the temperature gauge is starting to drift towards hot after a short drive and the reservoir tank is full like it has not lost a drop. I am baffled!
Sep 5, 2017 at 2:31 PM
