Engine shuts off right away and backfires
1999 PONTIAC BONNEVILLE
196,000 MILES • 3.8L • 6 CYL • AUTOMATIC
ASHLEE MARIE
  • 13 POSTS
Okay so I'm hopeless about my car. I have the car listed above SE model. Not supercharged. Originally the engine would turn on and it would start but then shut off after a couple seconds. Then I changed the EGR valve and the Mass Airflow sensor, and spark plug wires and it would run for longer and stay idling. But when I put it into gear it would shut off and backfire. Then I changed the spark plugs because the scanner was throwing a random cylinder misfire, which was I assumed to be spark plugs because I just replaced the coils and the wires and everything. Now I try to start it and it's back to square one. Shuts off right away and backfires. I've put over $350.00 into this thing to fix it and I still can't figure it out.
Jun 13, 2019 at 12:58 AM
Good morning,
Did you or anyone check the fuel pressure? It sounds like you need a fuel pump.
https://www.2carpros.com/articles/engine-stalls
Can you tell me the code number you had?
Jun 13, 2019 at 5:25 AM
ASHLEE MARIE
  • 13 POSTS
We checked fuel pressure. It's coming out in a clean stream. I can't get it to move to get someone to check it for me. It is throwing a po300 multiple cylinder misfire.
Jun 13, 2019 at 12:07 PM
I need the exact pressure. If it is too low, it will not run.
Jun 13, 2019 at 1:13 PM
ASHLEE MARIE
  • 13 POSTS
I don't have the tools for the exact pressure right now so I'd have to get it first.
Jun 13, 2019 at 2:43 PM
That's okay, I will be here. I need that to continue to help.
Jun 13, 2019 at 4:01 PM
ASHLEE MARIE
  • 13 POSTS
What are the chances it could be head gasket or timing chain?
Jun 13, 2019 at 7:37 PM
It is possible but need to verify basics before going to much larger issues.
Jun 13, 2019 at 11:18 PM
ASHLEE MARIE
  • 13 POSTS
I don't remember what it was reading but I was told it is fuel pressure regulator. how do I properly replace it? I have all the tools and such for it.
Jun 18, 2019 at 6:41 PM
Procedure below:
1. Relieve the fuel pressure. Refer to Fuel Pressure Relief Procedure. See: Fuel Pressure Release > Procedures
2. Clean any dirt from the fuel pressure regulator retaining ring.
3. Remove the vacuum hose from fuel pressure regulator.
4. Remove the snap ring (7) from the fuel pressure regulator.
5. Using a shop towel to catch any spilled fuel, lift and twist the fuel pressure regulator in order to remove the fuel pressure regulator (6) from the fuel pressure regulator housing (1).
6. Remove the regulator O-ring small (2).
7. Remove the regulator filter screen (3).
8. Remove the regulator O-ring large (4).
9. Remove the regulator O-ring back up (5).
10. Cover the fuel pressure regulator housing (1) to prevent contamination from entering the fuel system.
Jun 19, 2019 at 2:41 AM
ASHLEE MARIE
  • 13 POSTS
I was told I have to remove parts out of my car. The intake manifold gasket and such. That's what I'm the most confused about.
Jun 19, 2019 at 4:07 AM
That is inaccurate information.
The regulator is on the fuel rail in the back by the last cylinder at the firewall.
Jun 19, 2019 at 4:32 AM
ASHLEE MARIE
  • 13 POSTS
This. Correct?
Jun 19, 2019 at 7:25 AM
Yep. That is it.
Jun 19, 2019 at 7:32 AM
ASHLEE MARIE
  • 13 POSTS
Well then I bought an intake manifold for no reason. Yay. Alright I'm going to try this really quick.
Jun 19, 2019 at 7:37 AM
Okay.
Jun 19, 2019 at 7:42 AM
ASHLEE MARIE
  • 13 POSTS
It's not letting me go to the link to see how to release fuel pressure.
Just loosen the line slowly until the pressure bleeds off.
Jun 19, 2019 at 9:26 AM
ASHLEE MARIE
  • 13 POSTS
Got pressure tested. It's fine.
Jun 19, 2019 at 12:13 PM
ASHLEE MARIE
  • 13 POSTS
It runs and drives now. It just shuts off usually only when pulling into parking spots. It does not shut off when driving. Still throwing po300.
Jun 19, 2019 at 12:19 PM
What t.c is the fuel pressure?
Jun 19, 2019 at 12:29 PM
ASHLEE MARIE
  • 13 POSTS
If you're asking the number it ran to, it was 50ish. Mechanic I went to said it was fine.
Jun 19, 2019 at 12:58 PM
Pressure needs to be more exact.
Key On Engine Off 48-55 psi
The next thing I would check is the throttle body. Make sure it is clean of all debris.
Jun 19, 2019 at 1:11 PM
