Welcome back:
Not a problem. It has to be going somewhere. Is there anything under the vehicle? I'm not familiar with your vehicle, but usually when a water pump begins to fail, they will leak through a weep hole and it is evident. Don't laugh, but is there any evidence of coolant on the interior floor? A heater core can leak too. Also, a radiator cap that doesn't hold pressure can allow coolant to evaporate.
Let me know. Like I mentioned, I'm not too familiar with this vehicle, but I will try to help. If you see nothing leaking, what I suggest is to pressurize the cooling system to see if that helps and if it holds pressure. Take a look through this link:
https://www.2carpros.com/articles/radiator-pressure-test
Here is a general link discussing how to fix a coolant leak:
https://www.2carpros.com/articles/car-is-leaking-coolant
Let me know if that helps. I will watch for your reply.
Aug 19, 2019 at 6:52 PM
