Loose vacuum hoses
2001 FORD EXPEDITION
250,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
WAYNEMERTZ
  • 57 POSTS
I have used a smoke machine to locate a vacuum leak and discovered a loose vacuum line. It is back by the fire wall and I can not see or feel where it plugs in. Hope you can help me before I have to start tearing everything apart.
Wayne
Jan 26, 2019 at 5:43 AM
Hello again.
With the air filter assembly installed, is there a port for the hose to attach?
That is what it looks like it belongs.
Jan 26, 2019 at 6:06 AM
WAYNEMERTZ
  • 57 POSTS
No, there nothing on the air cleaner assembly.
I managed to get a camera close enough to take a video that might be showing a port.
I took a desktop photo of it.
Still can not get my hands on it!
May have to take off the throttle body, etc.
Wayne
Jan 26, 2019 at 6:26 AM
What about the open port on the throttle body? That hose is the same size?
Jan 26, 2019 at 6:29 AM
WAYNEMERTZ
  • 57 POSTS
No, that is huge, about ten times the size needed.
Jan 26, 2019 at 6:32 AM
The hose you pictured, at least that I saw, looked to be the same size as the throttle body fitting.
Jan 26, 2019 at 6:34 AM
WAYNEMERTZ
  • 57 POSTS
Let's try it from this point. From the original pictures I sent, with the two vacuum tubes in the harness (routing around the back of the engine) (one white and the other red) (one going to the fuel rail {maybe a regulator} ) Do you have any diagram where these two vacuum tubes are supposed to go? Something color coded? Right now the white one is connected to the fuel rail.
Wayne
Jan 26, 2019 at 7:09 AM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
The red line I saw in your picture goes to the fuel pressure regulator on the fuel rail.
Jan 29, 2019 at 10:55 AM
WAYNEMERTZ
  • 57 POSTS
Thanks Dave, I already had figured out that the white line when to the EVAP and the red line went to the regulator. But thank you very much for the reply.
Jan 29, 2019 at 11:06 AM
Dave has much better eyes than me. I did not even see that hose let alone the color.
Jan 29, 2019 at 2:29 PM
WAYNEMERTZ
  • 57 POSTS
Think about my poor memory at 73. Pulled the plugs off and a few days later forgot how they re-plugged in!
Jan 29, 2019 at 5:05 PM
Was that the only hose or is there others?
Jan 29, 2019 at 5:08 PM
WAYNEMERTZ
  • 57 POSTS
That was it. I had the white tube connected where the red one should have gone, and the white one went to the EVAP on the firewall. Thanks Roy and have a good night.
Jan 29, 2019 at 8:43 PM
You are welcome.
We are always glad to help.
Jan 30, 2019 at 3:10 AM
