Loose tilt on steering column
1989 CHEVROLET CORSICA
94,034 MILES • 0.6L • 4 CYL • RWD • AUTOMATIC
JOSHDOESLESSONS
Disassembled to replace ignition. Did not use wheel puller. Just yanked the steering wheel off now it is really wobbly inside the housing. I do not have the four "inverse torque bolt" just four regular bolts in birdfoot pattern and they are all tight. How do I tighten the column?
Aug 9, 2017 at 5:08 PM
STEVE W.
  • 15,113 POSTS
You have to disassemble the column down to the tilt assembly, then you can get to the bolts that hold the tilt assembly to the column base. You will need the special tool to remove the pivot pins to get the base off enough to get to the bolts that hold it together or watch this:
https://www.youtube.com/watch?v=Fuqc1iWG7gA
This covers some of it.
https://www.youtube.com/watch?v=i49sO9R_Lf4
https://www.youtube.com/watch?v=DqGNc7gE3uo
If you have already gotten that far and the bolts are tight. Remove them and see if you pulled the threads. There is not anything under the rest of it that would cause the tilt to loosen up unless the housing is damaged.
Aug 9, 2017 at 6:05 PM
