Loose or play in steering wheel when turning steering wheel
1998 ACURA CL
153,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
MAILMD32217
  • 23 POSTS
Greetings 2CarPros,
When I make a right turn while driving to turn right onto a different street, the steering wheel has a little bit of play when the steering wheel is turned to the far right. I feel and hear something that is loose fitting from the front suspension. What is it likely to be and how should I diagnose and repair the part in question?
M D
Jul 28, 2019 at 7:31 PM
It sounds like you have an inner or outer tie rod end that is loose you must raise the front of the car safety.
Then grasp the wheels and move them back and fourth to find the play. Use a flashlight, this guide may help:
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
Jul 30, 2019 at 12:22 PM
