Where is the ECT Sensor located?
2011 MAZDA B3000
180,000 MILES • 3.0L • 4 CYL • 4WD • MANUAL
KRITTER81
The temperature gauge is not working on my BT50. I am trying to troubleshoot but can't find the ECT Sensor. Where is it, please?
Jan 5, 2023 at 8:53 PM
The BT50 isn't offered in the US, but I will try my best to help. I need confirmation on the engine size. Is it a 4-cylinder or a 3.0L V6? Also, is it a diesel?
I will try cross-referencing it with the Ford Ranger to see if anything helps.
Jan 7, 2023 at 8:23 PM
KRITTER81
Hi Joe, it's a B3000 if that helps any. It is a 4 cylinder Diesel. Any help would be great.
Thank you
Jan 7, 2023 at 8:27 PM
BORIS K
  • 836 POSTS
The temperature gauge on instrument cluster receives its information from the ECM
(Engine Control Module) via CAN network
I would suggest first checking live data for the ECT (Engine Coolant Temperature) sensor in the ECM using a suitable diagnostic tool. This is to check that the ECM is receiving a plausible signal from the ECT sensor.
With ignition on and engine cold, stood over night, the ECT data should display ambient temperature.
Pin out from ECT sensor to ECM connector A
Pin 1, blue/orange wire to ECM pin A67
Pin 2, brown/yellow wire to ECM pin A56
I have looked in all my disposable technical information regarding the location of the ECT sensor.
None list the location. Below, in image 2, is where I believe the sensor to be at, near the outlet pipe to the radiator.
Input / Output Check Mode for instrument cluster
See image 1 below for related codes
• This function allows checking the input and output circuits of the instrument cluster. It
can be activated in the following way:
1. Press and hold the odometer/tripmeter switch, and turn the ignition switch to the ON
position.
2. Continue holding the odometer/tripmeter switch for approx. 5 s. until test is
displayed on the LCD.
3. Release the odometer/tripmeter switch within 3 s after test is displayed.
4. When the odometer/tripmeter indicates check code 00, push the odometer/tripmeter
switch to select a check code.
5. Inspect the check codes according to the W/M.
Some related articles which might be of help:
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
and
https://www.2carpros.com/articles/symptoms-of-a-bad-coolant-temperature-sensor
Also:
https://www.mazdabg.com/ftp-uploads/MAZDA%20material%20for%20technician/BT-50_en.pdf
This technical information covers the WL-C 2.5 16V engine but as the 3.0 engine is just a larger version so the information will be relevant
I hope this helps.
Cheers, Boris
Jan 8, 2023 at 1:24 AM
KRITTER81
Thank you, Boris, I will look into it. Fingers are crossed this help.
Cheers,
Kristy
Jan 8, 2023 at 1:57 AM
Boris, thank you as well from me. It's great to know you are there to help with these.
Jan 8, 2023 at 3:08 PM
