Long start
2009 NISSAN FRONTIER
100,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
NISSAN FRONTIER
If i let truck sit for a day or so the battery would drain. And now i drain the battery starting truck most times. And if it starts it takes a 20 second crank and most times with starting fluid. I am thinking fuel or spark? Have not tried anything yet. Note: if i use a battery charger you plug in it cranks slow but if i use a little booster it cranks good and fast, but still needs starting fluid and takes about 10 to 20 seconds to start. Okay, so after i get it running it drives okay even with lights on but if you turn off and try to start almost all the time no start and that's only after a few minutes.
Jan 29, 2021 at 7:07 PM
It sounds like a low fuel pressure issue. Try this and let me know what happens:
1) Turn the key to the run position and count to 5.
2) Turn the key off and repeat step 1 three more times.
3) On the fifth try, see if it starts easily.
___________________________________
If it doesn't, I need to know if you can get your hands on a live data scan tool. We will need to check what the engine coolant temperature sensor is sending the correct temperature reading to the computer. If it is way off, the air-fuel mixture will make it difficult for the engine to start and could require starting fluid for it to start.
Jan 29, 2021 at 8:50 PM
NISSAN FRONTIER
Thank you. I will try the start thing first and let you know.
Jan 31, 2021 at 10:57 AM
You're welcome. Let me know what you find or if you have other questions.
Jan 31, 2021 at 3:16 PM
