You shouldn't see any fuel from the vacuum hose. That is an indicator that the diaphragm is bad in the regulator. That would result in fuel pressure that is all over the place. Chances are the fuel system is building high pressure, causing the rich fuel mixture, and the added raw fuel is being drawn into the intake via the vacuum hose.
I would recommend replacing the fuel pressure regulator. I feel this is the likely problem.
Here are the directions. The attached pics correlate with the directions.
2000 GMC Truck C 1500 Truck 2WD V8-5.3L VIN T
Fuel Pressure Regulator Replacement
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pressure Regulator Service and Repair Procedures Fuel Pressure Regulator Replacement
FUEL PRESSURE REGULATOR REPLACEMENT
REMOVAL PROCEDURE
CAUTION: Refer to the Battery Disconnect Caution in Cautions and Notices.
pic 1
1. Disconnect the negative battery cable.
2. Remove the engine sight shield.
3. Relieve the fuel system pressure. Refer to Fuel Pressure Relief Procedure.
pic 2
4. Disconnect the fuel pressure regulator vacuum line.
5. Clean any dirt from the fuel pressure regulator retainer and the surrounding area.
6. Remove the fuel pressure regulator retainer (8).
7. Remove the fuel pressure regulator (9) from the fuel pressure regulator housing.
INSTALLATION PROCEDURE
pic 3
1. Install the backup ring (10) on the fuel pressure regulator (9).
2. Install the new large O-ring (11) on the fuel pressure regulator.
3. Install the regulator filter (12) on the fuel pressure regulator.
4. Install the new small O-ring (13) on the fuel pressure regulator.
5. Lubricate the fuel pressure regulator large O-ring and the small O-ring with clean engine oil.
6. Push the fuel pressure regulator into the regulator housing on the fuel rail.
7. Install a new fuel pressure regulator retainer (8).
8. Connect the fuel pressure regulator vacuum line.
pic 4
9. Connect the negative battery cable.
10. Tighten the fuel filler cap.
11. Inspect for leaks.
11.1.Turn ON the ignition for 2 seconds.
11.2.Turn OFF the ignition for 10 seconds.
11.3.Turn ON the ignition.
11.4.Inspect for fuel leaks.
12. Install the engine sight shield.
__________________________
Try this and let me know the results. Please feel free to ask questions if you have them.
Nov 1, 2020 at 8:06 PM
