It sounds like you are getting too much fuel. When you hold the pedal to the floor, the injectors shut down to eliminate a flooding issue. Is it possible for you to make a video with your phone of what it is doing so I can see it? Also, is there a smell of raw fuel when it does finally start?
_____________________________
Here are the directions specific to testing fuel pressure on this vehicle. Note that there is no schrader valve to connect the gauge. You need to do it at the fuel line. See the attached pics.
1997 Toyota Truck Tacoma Extra Cab 4WD L4-2693cc 2.7L DOHC MFI
Component Tests and General Diagnostics
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pump Fuel Pressure Testing and Inspection Component Tests and General Diagnostics
FUEL PRESSURE INSPECTION
1. INSPECT FUEL PRESSURE
(a)Check that the battery positive voltage is above 12 volts.
(b)Disconnect the negative (-) terminal cable from the battery.
pic 1
(c)Remove the union bolt and 2 gaskets, and disconnect the fuel inlet pipe from the delivery pipe.
HINT:
- Put a suitable container or shop rag under the delivery pipe.
- Slowly loosen the union bolt.
pic 2
(d)Install the fuel inlet pipe and SST (pressure gauge) to the delivery pipe with the 3 gaskets and SST (union bolt).SST 09268-45012
Torque: 29 N.m (300 kgf.cm, 22 ft.lbf)
(e)Wipe off any splattered gasoline.
pic 3
(f)Connect the Toyota hand-held tester to the DLC3.
(g)Turn the ignition switch on and Toyota hand-held tester main switch on.
Notice: Do not start the engine.
(h)Select the active test mode on the Toyota hand-held tester.
(i)Please refer to the Toyota hand - held tester operator 5 manual for further details.
(j)If you have no Toyota hand-held tester, connect the positive (+) and negative (-) leads from the battery to the fuel pump connector.
(k)Reconnect the negative (-) terminal cable to the battery.
(l)Turn the ignition switch on.
(m)Measure the fuel pressure.
Fuel pressure: 265-304 kPa (2.7-3.1 kgf/sq.cm, 38-44 psi)
If pressure is high, replace the fuel pressure regulator.
If pressure is low, check these parts:
- Fuel hoses and connections
- Fuel pump
- Fuel filter
- Fuel pressure regulator
- Injectors
(n)Remove the Toyota hand-held tester.
(o)Start the engine.
(p)Measure the fuel pressure at idle.
Fuel pressure: 206-255 kPa (2.1-2.6 kgf/sq.cm, 31-37 psi)
If pressure is not as specified, check the vacuum sensing hose and fuel pressure regulator.
(q)Stop the engine.
(r)Check that the fuel pressure remains as specified for 5 minutes after the engine has stopped.
Fuel pressure: 147 kPa (1.5 kgf/sq.cm, 21 psi) or more
If pressure is not as specified, check the fuel pump, pressure regulator and/or injector.
(s)After checking fuel pressure, disconnect the negative (-) terminal cable from the battery and carefully remove the SST to prevent gasoline from splashing. SST 09268-45012
(t)Reconnect the fuel inlet pipe to the delivery pipe with 2 new gaskets and the union bolt.
(u)Reconnect the negative (-) terminal cable to the battery.
(v)Check for fuel leakage.
______________________________
Nov 11, 2020 at 6:36 PM
