To access the sensor, you need to remove the air filter box. The sensor is on the top of the transmission housing. Here are the directions. The attached pics correlate with the directions.
____________________
2013 Honda Civic Sedan L4-1.8L (R18Z1)
Output Shaft (Countershaft) Speed Sensor Removal And Installation (A/T)
Vehicle Powertrain Management Transmission Control Systems Sensors and Switches - Transmission and Drivetrain Sensors and Switches - A/T Transmission Speed Sensor Service and Repair Removal and Replacement Output Shaft (Countershaft) Speed Sensor Removal And Installation (A/T)
OUTPUT SHAFT (COUNTERSHAFT) SPEED SENSOR REMOVAL AND INSTALLATION (A/T)
Service Information
Output Shaft (Countershaft) Speed Sensor Removal and Installation
Removal
1. Air Cleaner
pic 1
1. Disconnect the intake air duct (A).
2. Remove the air cleaner (B).
3. Remove the harness clamp (C).
2. Output Shaft (Countershaft) Speed Sensor
pic 2
1. Disconnect the connector (A).
pic 3
2. Remove the output shaft (countershaft) speed sensor (A) with the O-ring (B).
Service Information
Installation
1. Output Shaft (Countershaft) Speed Sensor
pic 4
1. Install the output shaft (countershaft) speed sensor (A) using a new O-ring (B).
pic 5
2. Check the connector (A) for corrosion, dirt, or oil, and clean or repair if necessary, then connect the connector securely.
2. Air Cleaner
pic 6
1. Install the harness clamp (A).
2. Install the air cleaner (B).
3. Connect the intake air duct (C).
________________________
Feb 26, 2020 at 8:09 PM
