Okay, so I tried to be an investigator and actually found the driver side blend door actuator in my Toyota Venza. It is located on the driver side of HVAC. Need to go under the crawling space underneath the driver side. I had to lay flat on my back, looking all the way up. My head was almost resting on the accelerator pedal. No need to remove any panel or anything. There are two small Phillips screw holding it. One screw is visible but another screw is absolutely hidden as it’s on the top side. I just unscrew that invisible screw by feel of it!. Detach the cable and it comes out.
However I realized that my blend door actuator may not be a problem. The driver side A/C was still blowing “warm” air when I manually turned the white plastic flap (I don’t know what it’s called) on one side. When I manually turned that white plastic flap all the way other side, the driver side vent blew “hot air”. Sorry I can’t explain accurately but I am sure experts know what I am talking about.
I think I may need the A/C refrigerant recharge.
I thank you for the advice and the words of encouragement, “you can do it”.
Pictures were difficult to take so they may not be directional.
May 27, 2020 at 4:16 PM
