Location of the thermoster in the engine
1998 OPEL SINTRA
ISAACSAMUEL2003
The engine is overheating on checking it was discovered that the fan is not working and there is need to check if the thermostat is good or bad but could not find it.Where is the location for the car cooling system thermostat.
I also want to know if the thermostat is responsible to start the fan after certain temperature have been reached.
Oct 25, 2013 at 10:09 AM
Does the engine overheat if you are driving at highway speeds, or is it only when in stop and go traffic?
Oct 25, 2013 at 5:27 PM
ISAACSAMUEL2003
it overheat when driving at high way speed and in traffic
Oct 26, 2013 at 3:28 AM
I just wanted to make sure before you put money into it that wasn't needed. If it overheats all the time, chances are it is the thermostat. I would also recommend flushing the radiator and cooling system when you replace the thermostat. A partially plugged radiator could cause the same problem.
Oct 26, 2013 at 4:39 PM
