Where is the Fuel Pump Relay located?
2008 NISSAN URVAN
150,000 MILES • 3.0L • 4 CYL • 2WD • MANUAL
JOHN ADANI
Fuel Pump Relay location and color needed.
Dec 27, 2024 at 12:30 AM
The fuel pump relay is intergraded into the IPDM which is under the hood and is not normally serviceable. But if it is look for a relay labeled "FUEL PUMP" or "EFI" (Electronic Fuel Injection). What problem are you having? FYI the fuel pump relay will not engage if you have a bad MAF sensor or the air intake tube is disconnected from the throttle body to the MAF sensor.
Dec 27, 2024 at 11:44 AM
