location of the flasher relay
2006 PROTON GEN-2
80,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
MARK TAYLOR2
hi I am having trouble locating then flasher relay, i can hear one clicking near the kick panel on the rhs
Mar 26, 2017 at 6:03 PM
HMAC300
  • 48,601 POSTS
this car is not sold in USA so we have not info on it. a lot of these are the hazard switch is diing both t/s an d hazard
Mar 27, 2017 at 6:48 AM
STEVE W.
  • 15,113 POSTS
That is probably the location then. I cannot find anything on this car other than they are sort of scarce. What is the problem you have other than finding the flasher?
Mar 27, 2017 at 7:03 AM
MARK TAYLOR2
hi Steve, I found the relay behind the kick panel I replaced it with a second hand one I had and it is working fine now, next job is replacing the fuel pump it just stopped working at the same time as the indicators, I thought the two problems might have been related but it doesn't appear to be.
Mar 27, 2017 at 1:59 PM
STEVE W.
  • 15,113 POSTS
I wish I could help. That is not a bad looking car. Yeah, usually the flashers get power from a different feed. I would hunt through the fuses and relays with a test light and make sure anything that resembles a fuel pump item is good.
I found where you can get a workshop manual for them but it's $200.00!
http://e-bookmanual.com/productsproton.html
And it looks like there is a bunch of information here, but you need to be a member.
www.protonownerclub.co.uk
Mar 27, 2017 at 4:36 PM
