Where is the starter located?
2007 CITROEN XSARA
102 MILES • 1.6L • 2WD • MANUAL
IANGEE
Hi all,
Just in the thick of trying to change the starter but there appears online so many different layouts of the Picasso engine I can’t see anything that helps. I sincerely appreciate any assistance.
May 16, 2023 at 3:09 AM
BRENDON S
  • 653 POSTS
Hello IANGEE,
Unfortunately, we are based in the United States, and I don't have any information for your vehicle. However, after doing some searching, I found a quick video I think will help you.
Here is the link: https://youtu.be/pasK_SR4pdg
This Video is for a 2006 Citroen Xsara but doesn't say if it is a 1.6L or not. Looks like it is on the back of the motor closer to the top. Removing the air cleaner might be necessary to gain access from above.
Let me know if this helps. If not, I will see what else I can find for you.
Thank you,
Brendon
May 16, 2023 at 5:09 AM
IANGEE
Cheers Brendon, found it mate! Thank you. yes air filter out and located just behind and under the head. Thanks very much.
May 16, 2023 at 7:00 AM
BRENDON S
  • 653 POSTS
Hello IANGEE,
You're welcome. Glad I could help!
Cheers,
Brendon
May 16, 2023 at 7:17 AM
