Where is Shifter Linkage located?
2009 BUICK LA CROSSE
100,000 MILES • 1.1L • 6 CYL • 2WD • AUTOMATIC
APRIL H.
No power to car. Starter is notworking. Battery is drained. Need to have a wrecker take to shop to repair. Where is the shifter linkage? Up top or down below please?
Oct 4, 2021 at 10:46 PM
The shift linkage is a cable that runs from the transmission to the steering column. I attached pics below showing it at the transmission and at the steering column. If you have a floor shift, it's the same design, but the cable runs from the floor shifter.
If you are trying to get the shifter in neutral to move it, there is a release button near the shifter. If you lift the trim on where the shifter is located, you will see a small pin. Depress it and shift.
Pics 1 and 2 are of the cable. Pic 3 shows the release.
I hope this helps. Let me know if you have other questions.
See pics below.
Oct 5, 2021 at 8:26 PM
APRIL H.
Thank you so much!
Oct 8, 2021 at 4:14 PM
You are very welcome. I hope it helped. Let me know if you have other questions or if there is something I can do to help.
Also, please feel free to come back anytime in the future if you have questions. You are always welcome here.
Oct 8, 2021 at 5:34 PM
