Location of crankshaft, knock and cam position sensors and remove and replace instructions needed
1998 NISSAN SENTRA
232,053 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
AZDANNO04
  • 343 POSTS
Need location of crankshaft, knock and cam position sensor. And process in order to remove and replace them.
Mar 10, 2021 at 1:01 PM
The crankshaft position sensor is located in the transmission bell housing. See pic 1 for location. The camshaft position sensor is in the distributor itself. You will need to remove the distributor cap to locate it. See pic 2 for location. Pic 3 shows the location of the knock sensor.
I'm not sure what you are dealing with, but it all seems tied into a timing issue, a misfire, or a no-start condition. Let me know what is happening. Hopefully, I'll be able to help.
Take care and God Bless,
Mar 10, 2021 at 6:35 PM
