location of power window relay
2002 VOLKSWAGEN JETTA
114,000 MILES • 1.8L • 4 CYL • TURBO • 2WD • MANUAL
MOHAA2113
  • 8 POSTS
Hi, All windows and central locking system stopped working. i checked all fuses and they were okay, but i read some forums i heard some talking about a power window relay or power door relays which could be the culprit. i checked under the driver side and saw some relays, but cannot tell which is either power window or power door relay. can someone please tell me the location of this relay(s) and the number written on it?any help is appreciated. Thanks
Aug 25, 2017 at 9:13 AM
This sounds like the main (drivers) window switch is bad becasue these is no relay, here is a guide and a wiring diagram to help you confirm the problem and get it fixed.
https://www.2carpros.com/articles/electric-window-repair
and
Check to see if the switch is getting power, if so try replacing the switch
Aug 26, 2017 at 11:57 AM
MOHAA2113
  • 8 POSTS
...thanks so much for the quick reply...I'll try all that you have suggested and get back to you within the week....cheers!!!
Aug 31, 2017 at 11:02 PM
MOHAA2113
  • 8 POSTS
Hi, i just set on to start all that I've been directed to try, but something happened and i want to explain it before i proceed...I removed the battery this morning to start a neighbour's car and when i installed the battery back on the car, everything including the windows started working but for some few hours now everything has stopped working again. I wanted to be sure, so i disconnected the battery and connected it again then it started working but for about thirty minutes now it has stopped... i found it necessary to forward this if it will help add some clues to the experts for further advice before i start tracing the main switch..thanks so much.
Sep 1, 2017 at 3:12 AM
It sounds like you are resetting the module controller in the drivers door. I would try to find a used one to plug in and try. Or use a test light and check the input and output voltage.
Sep 1, 2017 at 11:43 AM
MOHAA2113
  • 8 POSTS
Hi,mr.Ken thanks so much for your time, attention and advice through my problem and sorry for my delay in replying since last reply, i was on a village trip where i couldn't access any tools nor junkyards to work on my car. Am back now and have found a driver's door control module from a nearby junkyard, I'll try replacing it today and get back to you with the result. Thanks.
Sep 28, 2017 at 1:48 AM
Please let us know what happens and upload pictures or videos of the problem.
Sep 28, 2017 at 12:03 PM
MOHAA2113
  • 8 POSTS
Hi, I replaced the main door's module with another one but the problem still persisted. or could it be a sign of a failing ccm? Thanks
Sep 29, 2017 at 11:37 PM
Lets get back to basics before we go any further, here is a guide that will show you how to check for power at and through the switch
Please let us know what you find.
Sep 30, 2017 at 4:38 PM
MOHAA2113
  • 8 POSTS
thanks, yet on another trip I'll try and get back to you..cheers. you've been helpful.
Oct 7, 2017 at 6:26 AM
MOHAA2113
  • 8 POSTS
Hello, Mr. Ken. Before i proceed i would like to express my sincere appreciation to you and your efforts. you drew my attention to checking power through the switch the last time. indeed there was power and the brown wire was the ground. but when the car got frozen,(i mean the glasses and the central lock) i tested and now there was power in another wire again ( a small brown wire with a blue strip,it passes through all the doors to the ccm) so I'm sure there is some kind of bad ground somewhere. but to solve my problem temporarily, i decided to disconnect only one wire(that small brown wire gaining power) from the switch in the back door and voila!,it worked, the problem went away. i wanted to inform you earlier but i wanted to be sure before. So what do i do next? and remember, Thanks in advance
Nov 3, 2017 at 9:04 AM
I think you found the problem if you look at the wiring harness the brown wire is ground and the reason it has power is becasue it was looking for ground. Check out the wiring diagrams about to see what I am talking about.
We are getting closer :)
Nov 3, 2017 at 1:42 PM
MOHAA2113
  • 8 POSTS
Ok. I'll do that. Thanks in advance, Cheers!!
Nov 4, 2017 at 12:08 AM
